Brick Chimney Repair Pics - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-20-2011, 07:19 AM   #16
Rewards Points: 582
Originally Posted by mjzraz View Post
The only problem is a few spots like this where there was an air pocket and there is a hole in the concrete. can I fill these with something? looks like a place for water to sit and freeze that I don't want:
A bit of sharp sand and cement will fill the holes. Damp down the concrete a bit first. Nice looking workmanship.
stuart45 is offline   Reply With Quote
Old 11-20-2011, 02:36 PM   #17
Rewards Points: 150
Looks like a really professional job. One little point I noticed - did you have enough cement in the mortar mix as the new pointing looks very yellow, or is that because of the sand colour (that's how we spell colour). The mix for this sort of application should be 1:1:6 That's 6 parts sand, 1 part lime (for plasticity & stickyness) and 1 part cement and about 1 standard bucket of water. You can skip the lime, but the mortar will not be as smooth to apply. The sand should be 'brikies' sand, free of salt and a touch of clay. Here is a spec for different mortars; follow the link
www.abcbricksales.com.au/howtomortar.pdf
Cheers, Joe from big Oz
JoJo-Arch is offline   Reply With Quote
Old 10-31-2012, 06:37 AM   #18
The mortar has a color tint to it, the sand was a little on the yellow side as well. I tried to match existing, but it's tough, as it dries it changes color and the existing mortar is dirty which doesn't help.
mjzraz is offline   Reply With Quote
brick chimney on the side of a brick house kmw Building & Construction 3 04-22-2011 06:08 PM
Chimney leaking AgentW Building & Construction 43 12-23-2010 10:20 PM
Replacing a Brick Chimney GeauxCajuns82 Building & Construction 4 04-16-2009 07:20 PM
leak in chimney water comes threw brick Kdawg Roofing/Siding 51 02-08-2008 03:18 PM
Addition around existing brick chimney Adenmoor Building & Construction 2 11-20-2004 10:37 PM
