Brick Chimney That Needs Some Help! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-03-2007, 09:19 AM   #1
brick chimney that needs some help!
i have a 1888 house that has a brick chimney. the previous owner had it "repaired" by putting a coat of stucco on top (without any metal lathe) a couple of years later, it is just chipping and falling off. To me (and i'm no expert!) it looks like someone put different bricks in place to repair areas - because they are different colors.
is it advisable to remove the stucco and re-point the bricks or should i use metal lathe and cover it with stucco again? And finally, if i use a metal lathe, how do i attach it to brick?
thanks so much for any info!
brick chimney that needs some help!-img_0293.jpg   brick chimney that needs some help!-img_0299.jpg   brick chimney that needs some help!-img_0300.jpg
gemelli2 is offline   Reply With Quote
Old 10-03-2007, 12:41 PM   #2
Mod / ArchiBuilder
Cole's Avatar
To me it looks like that chimney needs to be rebuilt, going over it with stucco seems like a temporary patch.
But I am not mason and I am sure one will chime in.
Cole is offline   Reply With Quote
water leaking through brick chimney quigleybmd Concrete, Stone & Masonry 45 02-26-2013 04:26 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
Chimney - brick ? redline Building & Construction 3 05-23-2006 05:25 PM
Addition around existing brick chimney Adenmoor Building & Construction 2 11-20-2004 10:37 PM
