-   -   brick chimney that needs some help! (http://www.diychatroom.com/f19/brick-chimney-needs-some-help-12061/)
gemelli2 10-03-2007 10:19 AM
3 Attachment(s)
hi,
i have a 1888 house that has a brick chimney. the previous owner had it "repaired" by putting a coat of stucco on top (without any metal lathe) a couple of years later, it is just chipping and falling off. To me (and i'm no expert!) it looks like someone put different bricks in place to repair areas - because they are different colors.
is it advisable to remove the stucco and re-point the bricks or should i use metal lathe and cover it with stucco again? And finally, if i use a metal lathe, how do i attach it to brick?
thanks so much for any info!
amy
Cole 10-03-2007 01:41 PM
To me it looks like that chimney needs to be rebuilt, going over it with stucco seems like a temporary patch.
But I am not mason and I am sure one will chime in.
