Brick - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-04-2009, 04:46 PM   #1
brick
friend has a brick home, a good amount of the brick is coming off the house, no brick ties were used in the install. Was also told that some of the footing was going bad. Any idea to fix without breaking the bank?
Toolmaster is offline   Reply With Quote
Old 10-04-2009, 05:01 PM   #2
Rewards Points: 582
The brickwork might need rebuilding, depending on how bad it is. It is possible to use ties without rebuilding in some cases. This link will give you an idea. http://twistfix.co.uk/wall_ties/#
The footing could be expensive, depending on what is wrong with it.
stuart45 is offline   Reply With Quote
Old 10-04-2009, 05:28 PM   #3
Concrete & Masonry
Rewards Points: 620
I've done a few of these thru the years. I cant say I've ever used the "retro-fit" ties, have always just removed the brick & re-layed with new. A couple of reasons for re-laying is that normally, there is water damage behind these jobs also, new brick is a great way to update the look of house, & often times, it's less costly than one would think.
As for the foundation issue, that's a whole different can of worms. It needs an on-site inspection to even get a feel for what's wrong.
jomama45 is offline   Reply With Quote
Old 10-04-2009, 07:45 PM   #4
Rewards Points: 4,738
we call 'em ' brick ties ' here in the colonies we've used 'em for stabilizing against conc & cmu walls but never 2x4's/sheathing.
Old 10-05-2009, 03:43 AM   #5
Rewards Points: 582
We call the studs 4x2's ere on the mainland
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 03:07 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
New opening in a brick veneer wall - installing new brick ties? GrantJohnson Building & Construction 3 01-28-2009 10:17 AM
Sealing historic brick tenzo General DIY Discussions 2 11-22-2008 03:04 PM
