Breaks In Top Plate - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-21-2011, 10:07 AM   #1
Breaks in Top Plate
I'm framing walls in my basement and had a quick question about where to break top and bottom plates. For long walls I had heard that you should break plates on a stud. The problem is I'm building and raising the walls myself.
So I was wondering if it was ok to build the walls in 2 sections and join them with a double stud at the break so I can raise and secure them separately?
If I do break the plates on a stud, is it ok to break both the bottom and top plate on the same stud, or should I stagger and break them on separate studs?
If I break the plates over a stud, is it ok to break it over a window? All of my walls will be non-bearing, so only a single top plate and 2x4's on edge for headers.
Tarheel4985 is offline   Reply With Quote
Old 02-21-2011, 10:23 AM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
You're fine with breaking the plates in the middle of a bay.
I would not use a double stud.( it messes up your insulation width and can reek havoc with your sheetrock layout)
Cut your plate midway in a bay.
Make your top & bottom breaks in the same bay.
If you're framing at 16" oc, cut a 14-1/2" block to mend the plate from the underside and the topside of the shoe.
Try not to break over a window or a door
Small sections are much easier to handle. Snap lines on the floor & ceiling and fasten your plates securely to both and there shouldn't be a problem.
Good luck
tcleve4911 is offline   Reply With Quote
Old 02-21-2011, 10:39 AM   #3
I've done the double stud method making sure to keep the second wall stud back from the edge of the plate. this allows pulling the plates tight when fastening into the first wall stud. stud layout continues from original spot not new stud and as above try not to break over windows or door openings.
The older I get the better I was
Old 02-21-2011, 11:03 AM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
So is the next bay 13" wide vs 14-1/2" ?
HELP PLEASE replacing rotted sole, top and bottom plate dolson Remodeling 4 04-16-2010 07:54 PM
Replacing Section of Sole Plate RM575 Carpentry 3 03-28-2010 10:31 AM
Double sole plate how-to? HooKooDooKu Building & Construction 19 03-24-2010 02:43 AM
Getting Steel Plate Flush with Concrete Floor MrBill_DIY Flooring 7 11-29-2009 09:54 AM
OK to drill holes in top plate to run conduit? troll5501 Carpentry 4 05-11-2008 09:33 PM
