#1 |
bracing for 2x4 walls.
I have assembled walls to enclose an area 11' X 20'. one end is secured to an outside wall. there is no cieling, so the top is just open. the walls are not sturdy enough per the building inspector. he would not tell us what to do other than to say it must be more sturdy. we are planning on using two cross beams, each beam made up of two 2x6s nailed together. then using 2x4s cross ways to secure the encloser ends. will this work?
#2 |
In a little over my head
Stud walls are usually braced with either a "let in" diagonal 1x4 or sheets of plywood or OSB. Either one needs to be installed at a corner, nailed to the stud on the end and the bottom plate. The idea is to make a diagonal, tying the corner stud and bottom plate together.
#3 | |
Framing Contractor
bracing for 2x4 walls.Quote:
Joe Carola |
#4 |
Pictures Please.
#5 |
Haverhill Trade 1965
A few questions. Are there two or three walls, and is one end of each fastened to a wall? Are they walls inside a building, and are the cross beams going to be from wall to wall of the building? Since you say there is no ceiling I am picturing a roof above the walls do not go up to, is this right?
| Display Modes | |
| Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? | xray328 | Remodeling | 27 | 06-19-2011 09:50 PM |
| Delta-FL on floor and XPS on walls. Should I install the flooring or the walls first? | yotaman | Remodeling | 11 | 04-19-2011 10:20 AM |
| load bearing walls | worriedowner | Building & Construction | 3 | 02-02-2011 05:12 PM |
| How bad are unencapsulated knee walls? | deerhunter | Building & Construction | 0 | 11-02-2010 10:41 PM |
| Bracing for supporting walls | Bradley P | Building & Construction | 8 | 01-22-2008 08:44 AM |
