Braced Walls...Stud Sizes? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-23-2012, 01:04 AM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 2,120
As 'everyone' knows....there are several 'grades' of braced walls...
A, B, C, D, E...
A walls....2x4 for all studs....
B walls and higher...my drawings say this...
FRAMING AT FOUNDATION SILL PLATES AND ADJOINING PANEL EDGE STUDS SHALL BE A SINGLE 3xNOMINAL
MEMBER, AND ALL NAILS SHALL BE STAGGERED WITH 1/2" EDGE DISTANCE.
As we 'also' know....if the panel has a break (tall wall and the 4x8 sheet is not tall enough), the break has to be blocked.
So the question is (and I think I already know the answer)....when blocking between studs on B and higher braced walls, does the block have to be 3x lumber or larger?
ddawg16 is online now   Reply With Quote
Old 11-23-2012, 11:37 AM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
I do not believe that a 3x block is a code requirement.
The 3x sill and 3x edge studs are not a requirement either but are a darn good idea.
I think your house was done as engineered shear walls though and not braced wall panels, so of course this should be asked of the engineer of record.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 11-23-2012, 11:54 AM   #3
JOATMON
ddawg16's Avatar
To be on the safe side....I think I'll do 4x4 blocks....easier to do it now than have to do it over.....
BTW....braced vs shear.....I thought they were the same
Thanks for the input.
Old 11-23-2012, 12:02 PM   #4
AndyGump's Avatar
Rewards Points: 688
not many home owners as well as contractors are aware of the differences.
Braced wall panels are described in the CRC and are the "prescriptive" approach for anti racking, sliding and overturning.
Shear walls are designed by an engineer for the same.
Andy.
recurrent peeling paint on interior walls Krista2 Painting 14 09-10-2011 03:17 PM
Insulate/air seal shared walls in townhome? RebornRenov Building & Construction 4 01-07-2010 09:50 AM
Need help with very ugly basement walls GrandmaStormy Remodeling 5 03-05-2009 02:43 PM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 12:23 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 08:39 AM
