Boxing In My Load Center? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-21-2012, 11:30 AM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 1,812
I want to box in my load center all the way to the roof....in other words...hide the ugly pole. Only the front of the load center would be exposed.
So...do I just make a simple 'frame' out of 2x material...and cover that with left over OSB or plywood?
My wife suggested that we not take it all the way to the edge of the wall...instead, leave about 6" so that the down spout for the rain gutter can sit there (makes good sense to me)
One of my big questions....how to make the seal between the load center and the box. I don't want anything to be able to 'crawl in there' and make a home....
Old 08-21-2012, 09:21 PM   #2
Rewards Points: 264
What are you using for siding?
I wonder if attaching to the top of the load center and boxing in the conduit might be affected by a code restriction?
You might use down spout material to cover the conduit. I have seen where a vinyl down spout was used to hide HVAC lines. They split the back and put it over the line sets.
7echo is offline   Reply With Quote
Old 08-21-2012, 10:57 PM   #3
JOATMON
ddawg16's Avatar
Siding? No siding here....
The walls will be done in stucco
Old 08-22-2012, 05:46 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You might be able to use Slim Duct = Less labor & materials than boxing-in, and can be painted to match the color of the stucco:
LINK: http://slimduct1.com/
- Build Well -
Old 08-22-2012, 10:44 AM   #5
kwikfishron's Avatar
Rewards Points: 576
Id keep the size of the box minimal and stucco that too making sure the finish stays within the footprint on the meter box.
Rip a couple of boards to come out just slightly past the pipe and cap that with osb. 1xs would even be fine, since you still have access you could attach them from the back side.
kwikfishron is online now   Reply With Quote
Old 08-22-2012, 10:21 PM   #6
JOATMON
ddawg16's Avatar
That is pretty much what I was thinking....thanks for confirming.
Because of the way the door on my load center is designed, I can't go flush with the face....I have to be back about one inch to allow the door to pull down and then swing out....
Actually, I have to be 2" back...the stucco will be about 1" thick....
Thanks for the input guys....
Square D load center QO20M100 LAA2of3 Electrical 33 05-11-2015 11:28 AM
Mounting new load center to concrete block wall. speedster1 Electrical 77 09-09-2012 09:57 AM
Load center & grounding recommendations lesp Electrical 9 04-15-2011 11:14 PM
Load center vs. bottom fed Panel Board. Ugh. wmldwilly Electrical 8 04-23-2009 07:48 PM
CH42B200R Load Center for Detached Home Theater nomad4137 Electrical 6 07-21-2008 06:57 PM
