Boxing Around Ductwork - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-27-2010, 11:39 AM   #1
Boxing around ductwork
I'm refinishing my basement and I have ductwork that runs across the center of the ceiling. I'm planning to box it in and cover with drywall, then install suspended ceiling on each side. For framing around the ductwork, I'm going to use 2x2, building short walls on each side and joining them across the width. My question ... where the total width of the box is 6ft, to span two ducts, do I need additional bracing in the middle (between the ducts) to support the weight of the drywall when the box is finished, to prevent sagging?
gdoucette is offline   Reply With Quote
need help with package unit ductwork bekind42 HVAC 15 11-04-2011 03:13 AM
double walled ductwork question(s) peyton HVAC 8 04-19-2010 10:02 AM
plastic ductwork vs. metal: acoustic duct liners jjpclev HVAC 5 02-26-2010 07:29 PM
Moving ductwork to accomodate finished basement Badfish740 HVAC 1 01-13-2010 03:11 PM
Tapping into basement ductwork BasementVirgin HVAC 7 09-10-2009 09:01 PM
