Box Vents In Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-26-2011, 05:43 PM   #1
box vents in roof
Former owner insolated attic rafters without vent shute. The roof is new, and on back side of roof installed 2 box vents. My question is, what is proper way to vent roof, do i pull insolation, install vent shute and go with it or do i need to cut in ridge vent? There is soffit vent. Thank you!
remi is offline   Reply With Quote
Old 01-26-2011, 11:11 PM   #2
Registered User
Rewards Points: 5,216
The baffles stop incoming soffit air from wind-washing the insulation; http://www.bergerbuildingproducts.co...sAccuvent.html
You should have soffit vents in every rafter bay and a baffled ridge vent making a balanced system; http://www.oikos.com/esb/30/atticvent.html
http://www.airvent.com/homeowner/pro...it-specs.shtml
Gary
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 01:56 AM
Roof Vents for Very Hot Second Floor somewhatsketchy Roofing/Siding 1 08-11-2010 11:54 AM
roof over need vents? jgreaves Roofing/Siding 3 09-25-2009 09:23 PM
Rubber Roof and Roof Deck vianak Roofing/Siding 2 10-09-2008 06:37 PM
Hip Vents for 12/12 pitch roof - any suggestions woodworker2000 Roofing/Siding 5 10-26-2006 11:31 AM
