Box Steps For Newly Constructed Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-09-2012, 01:51 PM   #1
Box steps for newly constructed deck
I recently constructed a 12x20 floating deck and would like to add a box step to the front of it that would span almost the entire deck. My question is would I go with a ledger board in front? Or could a construct the box step separately? any other ideas? I have attached a photo for your viewing pleasure. thanks
jukeboxpunk is offline   Reply With Quote
Old 06-09-2012, 02:35 PM   #2
Rewards Points: 13,260
How high is it from the grade to the top pf the decking boards on the left hand side facing the deck?
The problum I see is slope, on one side the deck is so low it really does not need a step and the other side is at a slope.
If it was mine I would add vinyl lumber or composite fashia board to the rim joist and just add back fill to make the whole area even with a slight slope away from the deck. Then you would not need any steps.
Old 06-09-2012, 03:09 PM   #3
Backfill is not a bad idea too. Probably the cheapest and less time consuming.
The left hand side is roughly about 18" high from the ground to decking. The right is about 11". I probably don't need the additional box step, but it would really finish the deck off and conceal the deck blocks too.
Old 06-09-2012, 04:03 PM   #4
Rewards Points: 502
My pleasure in viewing your photo was spoiled by the dog's a**e.
tony.g is offline   Reply With Quote
Old 06-09-2012, 06:29 PM   #5
Haha that does take away from the scenery. Good one.
Old 06-09-2012, 06:41 PM   #6
Ideal step down height would be 7".
Old 06-12-2012, 01:14 PM   #7
Rewards Points: 29
I would attach it directly to the fascia board , we're only talking one step.
spinfisher is offline   Reply With Quote
Old 06-12-2012, 01:19 PM   #8
Yeah only one step. That's what I was originally going to do, my only issue being the uneven ground surface.
Old 06-12-2012, 01:40 PM   #9
DIY-er
Hi, it depends on your location, if you are subject to freeze-thaw cycles. If you don't change the existing grade, you will have to have 2 risers on one side, gradually changing to one rise on the other
KevinPh is offline   Reply With Quote
Deck Staining Nightmare steven994 Painting 6 04-06-2014 10:10 PM
foundation walls to support a deck bubbler Building & Construction 1 04-12-2012 04:27 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 12:36 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
