-   -   Box steps for newly constructed deck (http://www.diychatroom.com/f19/box-steps-newly-constructed-deck-146515/)
jukeboxpunk 06-09-2012 01:51 PM
1 Attachment(s)
I recently constructed a 12x20 floating deck and would like to add a box step to the front of it that would span almost the entire deck. My question is would I go with a ledger board in front? Or could a construct the box step separately? any other ideas? I have attached a photo for your viewing pleasure. thanks
joecaption 06-09-2012 02:35 PM
How high is it from the grade to the top pf the decking boards on the left hand side facing the deck?
The problum I see is slope, on one side the deck is so low it really does not need a step and the other side is at a slope.
If it was mine I would add vinyl lumber or composite fashia board to the rim joist and just add back fill to make the whole area even with a slight slope away from the deck. Then you would not need any steps.
jukeboxpunk 06-09-2012 03:09 PM
Backfill is not a bad idea too. Probably the cheapest and less time consuming.
The left hand side is roughly about 18" high from the ground to decking. The right is about 11". I probably don't need the additional box step, but it would really finish the deck off and conceal the deck blocks too.
tony.g 06-09-2012 04:03 PM
My pleasure in viewing your photo was spoiled by the dog's a**e.
jukeboxpunk 06-09-2012 06:29 PM
Haha that does take away from the scenery. Good one.
joecaption 06-09-2012 06:41 PM
Ideal step down height would be 7".
spinfisher 06-12-2012 01:14 PM
I would attach it directly to the fascia board , we're only talking one step.
jukeboxpunk 06-12-2012 01:19 PM
Yeah only one step. That's what I was originally going to do, my only issue being the uneven ground surface.
KevinPh 06-12-2012 01:40 PM
Hi, it depends on your location, if you are subject to freeze-thaw cycles. If you don't change the existing grade, you will have to have 2 risers on one side, gradually changing to one rise on the other
