Box Gutters? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-14-2013, 03:59 PM   #1
Rewards Points: 99
box gutters?
So more on my planned addition. its in the greek revival style and will be complimentary to the original structure, and I'm intending to build box gutters to achieve the distinctive look of the eves. would love to hear from anyone with experience with these. I understand the basics of design and construction, and plan to use copper for the liners, but unsure what to use for the lookouts and liner boards? treated lumber? dimensions? also how to achieve the grade necessary? shims on the lookouts or cuts? I'm sure some folks will call me crazy for this.
yellowkid is offline   Reply With Quote
Old 07-03-2013, 05:13 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,234
Keep us posted with picture updates. You are probably correct that folks (including me) think you are definitely taking the more labor intensive approach.
Be sure to not use PT lumber against the copper.
Old 07-03-2013, 06:25 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
Copper can be used with treated lumber. Aluminum can't. Copper is the primary ingredient in lumber treatment compounds.
http://www.advancedbuildingproducts....-shield-pc.cfm
Old 07-03-2013, 06:55 AM   #4
Good catch.
I am so used to not mixing metals because of the potential issues on roof valley and flashings that I completely overlooked that.
Old 07-03-2013, 02:47 PM   #5
As complicated as things have become, it's easy to miss something.
Old 07-03-2013, 05:44 PM   #6
Rewards Points: 79
You could hold the boxes level if they're tall enough to accommodate sloping gutter within their depth. Or am I just giving your own idea back to you?
eclark is offline   Reply With Quote
Gutters and Decorative Trim on Fascia paulyg Roofing/Siding 12 07-27-2010 02:54 PM
new drip edge over existing gutters scheiman Roofing/Siding 1 06-05-2010 07:44 PM
Leaking Gutters fripster Roofing/Siding 5 02-13-2010 08:25 PM
Box Gutters Fix or Aluminum? jonathan03 Roofing/Siding 4 01-01-2009 12:42 PM
Do I replace my gutters? nymark Roofing/Siding 5 06-18-2008 09:36 PM
