Bowing House Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-05-2010, 02:41 PM   #1
Bowing House Wall
Hi
I have had my house for about 6 years. It is a semi detatched. Over the last few months we have noticed a crack appearing on the inside of the outer wall. Also other tiny cracks appearing at the joins of outer wall and ceilin in other rooms and the wall seems to be bowing. We called out insurance as we were worried it was subsidence. A surveyor came out and said it not subsidence, there are no cracks on the external wall. He said it was the weight of the house and roof causing the wall to bow. The insurance will not cover it but he said it is a DIY job. Also he said all the other small cracks are due to the hot and cold weather, is this right as i have never noticed cracks in these places before. The surveyor said we just need to connect the wall to joists using braces. Does anyone know what this involves and also because the stairs are next to the problem wall how do we attach to joists without bars going straight across the stairs?
I would be very greatful for any information.
kcooper83 is offline   Reply With Quote
Old 04-05-2010, 03:06 PM   #2
kwikfishron's Avatar
Rewards Points: 596
A few pictures would be nice.
kwikfishron is offline   Reply With Quote
Old 04-05-2010, 03:26 PM   #3
I will try get some put on but there not much to see except cracks on inside of wall. Have you heard of attaching joists to walls with braces to stop them bowing further? Are there any sights around with information on this and how to do it? Is it as easy as surveyor made out?
Old 04-05-2010, 03:51 PM   #4
Is this a cathedral ceiling ?
Do you have rafter ties or collar ties in the attic ?
Old 04-05-2010, 03:54 PM   #5
Rewards Points: 596
Sure, you can brace just about anything but that might not be the fix. Try to get a picture from the inside and also from the same place on the outside.
Old 04-05-2010, 04:08 PM   #6
Rewards Points: 5,336
It could be truss movement if the roof had an inordinate amount of snow this year.
Ron
Old 04-05-2010, 04:16 PM   #7
Not sure about the ties, will have to check this. The surveyor said we have a gable wall with a hipsided roof, slopes on all 3 sides, if that helps.
Cathedral ceiling?...maybe...there are beams showing in the 2 corners of the ceiling next to de tatched side of house. Ceiling is not at right angle to walls, it curves at edges. Flat part of ceiling is higher than level of guttering if that makes sense.
As you can probably tell i am completely new to all this. I just want to make sure what surveyor said is correct.
House construction is difficult to explain, i will get some pictures done to help.
Old 04-06-2010, 08:46 AM   #8
Rewards Points: 582
These may help explain how restraint straps are fitted.
stuart45 is offline   Reply With Quote
Old 04-09-2010, 10:12 AM   #9
Thanks everyone for taking the time to reply and post diagrams.. We had a survey done by an engineer through insurance to make sure it wasn't sub-sidence, got the report back today. This is what it said we need to do:
The gable wall should be tied in to the structure at wall/floor levelby means of 30 x 5mm pre-drilled and galvanised metal straps at 1.2mtrs centres. The straps require mechanical fixing to the external wall and should be screwed to the side, top or bottom of the internal floor/ceiling joist timbers/internal partition. If there are window or door openings, two straps should be fitted either side of the opening to make up for any missing straps.
The engineer did say it was a DIY job. Is it really possible to do this kind of job yourself? Or would it be better to get someone to do it? If so any idea how much it will cost?
Old 04-09-2010, 10:29 AM   #10
pics really would help. ones that show a large area both in and out
The older I get the better I was
Old 04-09-2010, 10:40 AM   #11
Rewards Points: 596
Sounds like a gable wall that should have been balloon framed and wasn’t. I understand the straps but don’t see how that would correct the bow in the wall. Either way the siding or the drywall will have to come off to install the straps.
Old 04-09-2010, 10:55 AM   #12
These are best i could do.
Bowing House Wall-100_5949.jpg   Bowing House Wall-100_5954.jpg   Bowing House Wall-100_5955.jpg   Bowing House Wall-100_5956.jpg   Bowing House Wall-100_5957.jpg
Old 04-09-2010, 11:07 AM   #13
Rewards Points: 596
Is that plaster over brick?
The inspector said "gable wall", I see no gables.
Old 04-09-2010, 11:09 AM   #14
Yes it is plaster over brick.
Old 04-09-2010, 11:12 AM   #15
I did think gable wall was when only 2 sides to roof and end wall goes into triangle at top but thats what he called it.
Tags
bowing wall , cracks in wall
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Sealing exterior wall from inside the house? BigJimmy Building & Construction 6 03-20-2007 09:16 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
