Bowed Door - How To Straighten It Out? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-28-2009, 03:32 AM   #1
Rewards Points: 1,016
Bowed door - how to straighten it out?
New hollow core door - was probably exposed to some water during storage prior to installation. No visible water damage or marks. Lay a long straighedge on and about an 3/8" of bow is right in the center. It's going into a pocket door frame so has to be pretty true.
Suggestions on how to un-bow it? I have thought about laying it across a couple saw horses bow side up with some weight on it and leave it in the sun for a couple days.
Thanks!
Old 07-28-2009, 05:54 AM   #2
Your on the right tract IMO, But it is going into a pocket which as you stated has to be true. Personally I would just go buy another hollow core door if the bow doesn't remedy itself with the weight sun cure idea. I can get them pretty cheap from a resale auction. Now I do not know if you have this type of resource at your disposal but, Good Luck.
mark942 is offline   Reply With Quote
Old 07-28-2009, 08:54 AM   #3
Registered User
Termite's Avatar
Yup, that thing would go in the dumpster. Hollow core doors are pretty inexpensive so I'd opt for a new perfectly straight one, especially since it is a pocket door. If it got wet enough to warp I'd have concerns that the adhesives could fail or are in the process of failing from moisture exposure.
Straighten Nylon Fish Tape? fw2007 Electrical 9 03-11-2008 04:58 PM
bowed ceiling akobari Building & Construction 14 10-23-2006 06:17 PM
