Bouncy Squeaky Floor, But Wait There's More, Free Floating Sills - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-25-2013, 07:20 PM   #16
Msradell's Avatar
Rewards Points: 84
Originally Posted by 123pugsy View Post
Sure looks like a serious issue to me.
Cement nails were supposed to hold the sill plate down which held the floor joists that hold up the cantilevered wall and weight of the roof?
Now the sill plate needs bolting down to do the job it's intended to.
Or am I missing something here?
Well you did miss the point that cement nails are not an acceptable method for attaching the sill plate to the foundation! Cement nails are not designed to counter up lift forces. Code requires anchor bolts that are cemented (or epoxied) into the foundation walls and possibly strapped.
Msradell is offline   Reply With Quote
Old 12-25-2013, 07:40 PM   #17
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 404
I know cement nails are not for that purpose.
Just wasn't sure if what I posted was exactly what was going on.
It appears that the floor joists are indeed teeter tottering on the support beam pulling the sill plate up off the wall.
How long before that front wall drops some more?
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
Old 12-27-2013, 01:01 PM   #18
Registered User
Rewards Points: 4,912
I agree, with a 34' truss on a cantilever with less than code back-joist, they should have at least strapped them down to a bolted sill plate; http://publicecodes.cyberregs.com/ic...9_5_par022.htm
Gary
Old 12-28-2013, 09:55 AM   #19
KemoSabe
loneframer's Avatar
It appears that an attempt was made to "beef up" the end of the beam that supports the corner of the building. It also appears that the end of the visible scab is tipped up between the columns. Looking at the unit next door, the column is closer to the end of the beam. The fact that you state all the windows and doors are operating properly and there are no structural cracks apparent indicate that the problem existed before the finishes were installed.
At this point, there's not much you can do but to stabilize and monitor the condition.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Glue together floating floor, bouncy from un level subfloor palabalo Flooring 9 05-14-2013 02:22 PM
Re-leveling free floating deck Bone244 General DIY Discussions 3 04-24-2011 09:09 AM
Installing floating floor over squeaky wood floor- rip it up? (Q3) cee2ski Flooring 1 02-09-2009 07:23 AM
