Bottom Plate For Stud Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-10-2012, 01:52 PM   #1
Rewards Points: 111
Bottom Plate for Stud Wall
Hello,
I am in the process of finishing my basement. I am going to use 2x4 lumber for the stud wall and bottom/top plates. I first laid down a subfloor (http://www.ovrx.com/basement-flooring.html) going up to the concrete foundation walls (leaving a small gap for expansion), its XPS foam board on bottom, with OSB tongue and groove wood on top, the product is supposedly 1 1/8" thick. I am going to place my stud wall on top of the subfloor.
My question is, what is the best way to attach the bottom plate to the floor (through the subfloor and anchor to the concrete slab)? I was looking into the powder actuated fasteners, but the max length of the nails for that is 3", that doesn't seem long enough, anyone know if they make 3.5"?
3" pin - 1.5" bottom plate - 1 1/8" subfloor = 3/8" embedment of pin into concrete (actuated fasteners call for 1" min.). If they made a 3 1/2" pin, that would be good, but I can not find those anywhere. Is 3/8" embedment into concrete enough since it is being attached to the OSB subfloor, plus going into concrete? I couldnt find 3.5" concrete nails either. Would i need to use a longer tapcon screw? I didnt want to have to drill that many holes, and then screw in the concrete tapcon screws. I have approx 150' of bottom plate to be attached, so at 4' centers for anchoring, your talking 35-40 anchors minimum.
Thanks in advance,
Steve
svaic00 is offline   Reply With Quote
Old 07-10-2012, 01:54 PM   #2
Your wall studs should sit on the concrete floor...not on top of the subfloor you laid down.
pkrapp74 is offline   Reply With Quote
Old 07-10-2012, 01:57 PM   #3
Framing Contractor
Originally Posted by svaic00
Hello,
Thanks in advance,
Steve
The bottom plate gets nailed to the sunfool and nothing else.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 07-10-2012, 02:07 PM   #4
Rewards Points: 111
The subfloor is a floating subfloor though, I wanted to anchor the wall down into the concrete, and anchor the edges of the floating subfloor down for when i go to pull carpet, the subfloor wont be pulled up, or buckle upwards.
Basement wall bottom plate Jeff0101 Building & Construction 7 01-08-2012 06:35 AM
Attaching bottom plate to concrete at edge near wall BlueBSH Building & Construction 13 06-13-2010 04:05 PM
HELP PLEASE replacing rotted sole, top and bottom plate dolson Remodeling 4 04-16-2010 06:54 PM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
Rewiring old house, Hit brace in outside wall, Safe to drill through Bottom Plate. twilightcall Electrical 2 06-29-2008 11:36 PM
