Bottom Plate Capillary Break - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-12-2012, 04:53 PM   #1
Rewards Points: 154
Bottom plate capillary break
Hi All, can I use this sill gasket under my bottom PT plate as a capillary break for an outside wall in a basement?
pete0403 is offline   Reply With Quote
Old 02-12-2012, 06:25 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
What's a capillary break?
titanoman is offline   Reply With Quote
Old 02-12-2012, 06:26 PM   #3
Rewards Points: 14,306
Sure, that's what it's made for.
Tom Struble (02-12-2012)
Old 02-12-2012, 06:31 PM   #4
Rewards Points: 1,766
Read about it here:
http://www.owenscorning.com/around/i.../foamsealr.pdf
bob22 is offline   Reply With Quote
Old 02-12-2012, 09:17 PM   #5
Rewards Points: 154
Thanks a lot for the quick replies!
Old 02-12-2012, 09:52 PM   #6
Registered User
Rewards Points: 526
WOW, all I need to see now is a question on air sealing the basement drywall, LOL. Sorry Pete, it's ironic because I've suggested using s.s. for over 2 years here and that's the first time anyone ever suggested using it specifically. Thank you, I was pleasantly surprised.... It's also an air break stopping air movement under the plate and a thermal break, to stop the warm studs from warming the plate/concrete slab/ground.(A heat sink) If your local Inspector requires fire-stopping studs tight to the concrete wall (every 10' lineally-rigid foamboard between them) the s.s works well to isolate that every 10' stud from the standard layout studs for a thermal break there also.
Gary
Rotten Stub and bottom plate against exterior wall markx Carpentry 2 05-26-2011 11:51 PM
Cut Doorway Bottom Plate on Concrete OhioDon Building & Construction 3 12-09-2010 11:19 AM
OK to drill holes in top plate to run conduit? troll5501 Carpentry 4 05-11-2008 08:33 PM
basement renovation yummy mummy Remodeling 156 05-08-2007 10:15 AM
Help! I need to know how to start finishing my basement. brightred Carpentry 47 01-18-2007 01:30 PM
