Old 10-31-2012, 05:53 PM   #1
Question
Boring through supporting beam
We are in the middle of a kitchen remodel. We want to move the AC vent over but there is a 1X12 between where the vent is and where we want it to be. Can I bore a 6" hole through the 1 X12? Oh, this is on the bottom floor of a two story home and the beam is already sistered to another 1 X 12.
Jennylynn is offline   Reply With Quote
Old 10-31-2012, 06:01 PM   #2
Got a picture?
Not sure why there would be 1 X 12's used other then for shelves. Sure you do not mean 2 X 12?
If it's 2, 2 X 12 then that's what holding up the middle of the house
Old 10-31-2012, 06:03 PM   #3
GBrackins's Avatar
jennylynn,
welcome to the forum!
are you asking if you can bore through a floor joist? I believe if it is a floor joist it would be 2x12 not 1x12.
this link will provide you with the prescriptive code requirements for notching or drilling floor joists. you will notice that none of the sketches provide for removing 50% of the depth of the joist.
not what you wanted to hear I'm sure .....
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
Jennylynn (10-31-2012)
Old 10-31-2012, 06:06 PM   #4
GBrackins's Avatar
if this is your center beam the same applies ....
Gary
Old 10-31-2012, 06:11 PM   #5
It might be possible, but you will have to do some additional framing to transfer the load to the adjacent joists. You can't just cut out 50% of the joist anywhere without adding some framing, and it really depends on how far along the joist you are with regard to how large of notches and holes you can make (which are all less than 50%).
Take a picture and post it as well, if its truly a 1x12, that would be strange.
patented is offline   Reply With Quote
Old 10-31-2012, 06:26 PM   #6
Yes, 2 X 12, not 1 x 12
And we ordered a steel reinforcement plate to reinforce the load as well. I just want to make sure we are doing it right the first time. I di not want to cause any structural damage to the house.
Old 10-31-2012, 06:32 PM   #7
GBrackins's Avatar
Jennylynn,
as joe and patented said, "got some photos?" helps in providing suggestions to your problem
Gary
Old 10-31-2012, 11:52 PM   #8
Ok, I will get photos if needed, but this is a 2x12 pine joist. It is also sister-ed with another 2x12. From what I've seen, we can run a 6" hole through a double 2x12 joist. Correct? Anyone know of additional framing required? I know this cannot be done through a single 2x12, but if it's sistered...
Old 11-01-2012, 07:48 AM   #9
Framing Contractor
A simple call to your building inspector will get you your answer. He/she has to inspect it anyway. Will you call and ask? Do you have permits?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 11-01-2012, 08:52 AM   #10
If someone spec. A doubled up beam that wide there's a reason.
Check the hundreds of older post asking how to level there sagging floor cause by cut or sagging main beam. Now there facing having to replace or lift the beam.
Old 11-01-2012, 09:25 AM   #11
GBrackins's Avatar
once you post some photos maybe someone will agree with you .... we need to see what it is you have
there is a difference in a joist and a beam
Gary
Need advice -home inspector pointed a problem - metallic pole not supporting beam skRyan Building & Construction 28 02-28-2012 10:46 PM
drilling through steel I beam DIYguy2000 Building & Construction 3 11-21-2011 09:39 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Main Beam De-Laminating Bird Doo Head Building & Construction 6 12-09-2010 01:08 PM
Rotted Lookout Beam Supporting Barge Rafter rwbil Building & Construction 1 08-15-2010 12:40 PM
