Boring Holes In A Load-bearing Bottom Plate - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-20-2009, 06:58 PM   #1
Rewards Points: 508
Question
Boring holes in a load-bearing bottom plate
Hi folks,
I plan to bore a 1-1/4" hole (36 percent of 3-1/2") in a 2x4 bottom plate (bearing, exterior wall) to accommodate 1" Wirsbo Aquapex coming from my well pump in the basement and supplying my tankless water heater in the attic. Will this scenario pose a structural problem? What about a 14.5" length of lumber inserted between the studs to double up the bottom plate. I guess the point of contact between the rim joist and the bottom plate bears most of the load, right?
Thanks,
Ben in North Jersey
benjamincall is offline   Reply With Quote
Old 01-20-2009, 07:12 PM   #2
No, this won't pose a structural problem. Taking it out of a load bearing stud may (should stay below 25%) but not the bottom plate.
Reilley is offline   Reply With Quote
Old 01-20-2009, 07:19 PM   #3
Rewards Points: 508
Awesome! Thanks for the quick response!
Old 01-20-2009, 07:28 PM   #4
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,344
Running a water line in exterior wall isn't a good idea, it's prone to freezing.
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
Old 01-20-2009, 08:59 PM   #5
True. You'll want to keep the lines on the warm side of your vapour barrier.
Being that he is putting his water heater in the attic, I will assume he is in a warm climate.
Old 01-20-2009, 10:05 PM   #6
Rewards Points: 508
Tell me about it
I discovered a river springing from the side of my house where somone had run copper on the wrong side of the insulation. Here in New Jersey we had record-setting cold temperatures and very little heat in house (electric space heaters on the main floor). I hope we'll be OK given the diameter of the PEX and the fact that I'm going to put it on the interior side of the insulation. Do you think I need to sleeve the PEX in foam insulation before it hits the attic? I intend to replace the siding, so what about Dow EPS sheathing on the outside? I don't really have many options to route the PEX to the attic. I spoke with Rheem about the installation and they said that the water heater has an anti-freeze mechanism. Of course the manual says you should drain the thing when you expect freezing temperatures. I'm not sure what to believe. Any ideas?
Old 01-20-2009, 10:18 PM   #7
NJ is not exactly considered a "warm climate"
TBFghost is offline   Reply With Quote
Old 01-20-2009, 10:46 PM   #8
I have gas!
Is your attic space inside the envelop? If not I wouldn't put the water heater there. Even though the water heater will protect itself from freezing, the pipes and fittings won't.
Old 01-20-2009, 10:47 PM   #9
Rewards Points: 508
New thread?
Maybe I should start a new thread on the attic tankless installation.
Old 01-20-2009, 11:03 PM   #10
Rewards Points: 508
Envelope
I understand "envelope" to mean the portion of the house that is sealed off from the oudoors, i.e., not my vented attic. What would you think about extending the envelope to a small portion of the attic?
Old 01-20-2009, 11:16 PM   #11
Rewards Points: 508
According to Rheem:
A confined space is one having a volume
of less than 50 cubic feet (1.4 m
3) per
1000 Btuh (0.3 kw) of the aggregate input
of all appliances within that space.
Pretty much any enclosure I build up there will require a huge vent, so I'm not sure what I'd accomplish. Want to trade me your direct vent model?
Old 01-20-2009, 11:17 PM   #12
Registered User
Termite's Avatar
Good idea. You're asking for all sorts of problems putting a tankless unit and the associated pluming in an unconditioned attic space.
You're ok drilling the hole in the plate. Not a problem. Nailguards will be required at the plate penetrations.
Old 01-20-2009, 11:56 PM   #13
Rewards Points: 508
What is a reasonable way to modify the attic for my install? I can't conceive of any place I could put it in my basement. What about a small enclosure with a louvered vent to the living area? I could easily tap in to over 10,000 CF of living space that way.
Old 01-21-2009, 11:05 AM   #14
Rewards Points: 20
I don't know much about the tank less water heater but I have seen pex freeze. Granted it was 1/2" but even 1" will freeze, just take a little longer. I live in Wisconsin and deal with the same freezing temps as you. I would not put anything water related in the attic or on the exterior walls.
ponch37300 is offline   Reply With Quote
Old 01-21-2009, 12:35 PM   #15
I have gas!
You have a basement and there's not enough room on any exterior wall to hang it? Wouldn't it be much simpler to drill the vent through the foundation and run water lines from the well?
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 08:50 PM
OK to drill holes in top plate to run conduit? troll5501 Carpentry 4 05-11-2008 08:33 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 07:37 AM
moving another load bearing nailfun Carpentry 2 02-20-2007 08:10 AM
