Old 04-20-2009, 02:29 AM   #1
Post
Book on cinder block home construction
Does anyone knows of a good book on how to build a home with cinder block, plumbing, electrical work etc.
Thank you for any help!!
Miguelon
MIGUELON is offline   Reply With Quote
Old 04-20-2009, 07:09 AM   #2
For electrical, Electrical Wiring Residential, by Ray Mullin, 16th edition covers 2008 NEC. Similar books on plumbing online or Borders, Barns/Noble. Not sure on block houses, you don't see that much anymore, not energy efficient.
Old 04-20-2009, 07:30 AM   #3
Check out HUD information on block homes. Not that long ago they did a study on all block construction for homes. Block homes ARE very energy efficient if constructed properly. A block home will out perform a stick built house in almost every way. It is an excellent method of building if done right.
NJ Brickie is offline   Reply With Quote
Old 04-20-2009, 10:05 AM   #4
Old School
Willie T's Avatar
If you're going to have to learn a whole new system anyway, why not drag yourself all the way into the 21st century?
Check out this... http://www.eco-block.com/
Look under Product Information (Installation Manual)
Might as well build the way all the progressive companies are already going. It beats both block and wood, hands down!
Willie T
Old 04-26-2011, 11:37 AM   #5
That is not necessarily even close. There are a lot of variables in the equation on this, the heating thereof being one of them. IMO, anyone building a concrete house needs to consider the practice very carefully. It can work, and it can be a disaster.
Brick Ledge when using cinder block DaveMo Building & Construction 5 07-13-2011 10:46 AM
Installing a new windows in cinder block foundation monsterbash Building & Construction 1 04-13-2009 08:48 AM
Half-height Cinder Block wall Electrical theatretch85 Electrical 11 04-09-2009 12:49 AM
Venting dryer through cinder block foundation wall jayp Building & Construction 10 04-08-2009 07:18 AM
do it yourself home construction toby72 Building & Construction 4 06-20-2006 12:32 PM
