Bonding Wood To Concrete. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-26-2011, 09:08 AM   #1
bonding wood to concrete.
I want to install 2"X4" boards to a 12'x12' patio slab that is 2" thick. I was told that drilling along the patio borders would crack the concrete. Is there a product avaiable that will bond wood to concrete?
cvzimbaldi is offline   Reply With Quote
Old 04-26-2011, 10:00 AM   #2
SteelToes's Avatar
Rewards Points: 150
There are many products available which will bond wood to concrete but in your case adhering wood (24x48 plywood?) directly to concrete its a wrong practice at the first place especially doing so on the patio slab.
SteelToes is offline   Reply With Quote
Old 04-26-2011, 10:31 AM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
True. The wood will absorb moisture from the concrete and rot out quickly. You want something between the two to stop this from happening.
If you will edit your original post, or let us know what you want to do, someone here may have a suggestion.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Anyone covered stained concrete flooring with wood? jcieutat Flooring 11 12-12-2009 11:19 AM
gluing wood to concrete kathy k Carpentry 11 08-16-2009 10:51 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
