Bond Strength Of Mortar??? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-05-2009, 11:19 AM   #1
Question
Bond strength of mortar???
I am building an outdoor fireplace in Phoenix, Arizona using CMUs and type S mortar. Since it is the summer (temperatures about 100 to 110 degrees or more), I want to make sure that I am mixing the mortar to a consistency that will achieve maximum flexural bond strength.
For hot weather, what would be the proper consistency for mortar?
Should I be retempering the mortar?
How long is a batch of mortar good in such weather conditions?
Should I wet the CMU before construction?
Should I mist the CMU after construction?
Is there a method to field test the bond strength of the mortar, so I can be assured that the construction will last?
Should I cover the block (shield it from the sun) for a period of time after construction?
figs is offline   Reply With Quote
Old 06-05-2009, 11:35 AM   #2
Old School
Willie T's Avatar
I am building a fireplace in Phoenix, Arizona using CMUs and type S mortar. Since it is the summer (temperatures about 100 to 110 degrees or more), I want to make sure that I am mixing the mortar to a consistency that will achieve maximum flexural bond strength.
For hot weather, what would be the proper consistency for mortar? You want the same consistancy as in any weather. It still has to support and level the blocks.
Should I be retempering the mortar? Never a great idea, but necessary sometimes to maintain workability.
How long is a batch of mortar good in such weather conditions? I wouldn't try for over an hour in such hot conditions.
Should I wet the CMU before construction? Always.
Should I mist the CMU after construction? If the sun is that bad, wouldn't hurt.
Is there a method to field test the bond strength of the mortar, so I can be assured that the construction will last? All I can say here is just mix it right.
Willie T
Old 06-05-2009, 01:14 PM   #3
http://www.cement.org/masonry/compressive_strength.asp
Old 06-05-2009, 03:06 PM   #4
Rewards Points: 1,220
You can generally re-temper once with no issue, plus keep it shaken up on the board. Dip or spray your block before laying. There is no practical field test for bond strength other than a good kick. The main thing is that for your application, it is not that critical.
That article deals with compressive strength, not bond strength.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 06-05-2009, 07:10 PM   #5
Right you are
"The maximum adhesion strength of a mortar applied onto a substrate, which can be determined by shear or tensile strength test.
www.netweber.co.uk/header/help.html"
One requirement is
"Tensile strength= 0.1 to 0.2 MPa."
which is 15 to 30 psi, not all that high.
Old 06-05-2009, 10:19 PM   #6
Compressive and bond share a relationship, but it is not direct.
Old 06-06-2009, 10:46 AM   #7
Unfortunately I couldn't get into the reports that this search
http://www.google.com/search?client=...UTF-8&oe=UTF-8
generated.
Old 06-06-2009, 04:23 PM   #8
As a rule, you will always want to use the weakest compressive strength mortar possible in context with the masonry units being laid, as that will provide the best flexural and bond strength. Mortar is not concrete, and the desired physical properties of each are very different.
Basement Wall Mortar rory535 Building & Construction 16 08-06-2009 10:39 AM
reapplying mortar to bond Ditra to Hardi Backer Board Tim Bingham Remodeling 9 06-02-2009 04:21 PM
Removing mortar bed Cosmo Brown Flooring 2 04-05-2009 12:54 AM
Is it bad to use mortar to level a floor? CB2007 Flooring 4 10-01-2008 09:38 AM
Mortar removal from salvaged brick. Rem8 Building & Construction 8 07-20-2008 08:05 AM
