Old 09-11-2012, 11:25 AM   #1
Bolting Rigid Awning To House
I'm headed off to the welder later today to have an awning frame built to cover the first 6.5 feet of my deck. What I'm lost on is how to tie this acrylic/polycarbonate awning into the exterior wall of the house.
I'm going to get panels similar to what are used in greenhouses to make a clear sloped awning and the welder should probably be able to figure out the framing design. Since I have very thick stucco, I'm concerned about how I can bolt the top of this apparatus to the wall. My initial thoughts were to bolt maybe a piece of heavy aluminum angle across the top and then build off from there.
The wood frames on either side will be "green walls" and the framing will be bolted to the top of either side. I also thought I might remove that unnecessary gutter below the balcony and just flash off that onto the awning, but that might look a bit trashy.
Here's a pic of the side angle. Any thoughts? Thanks!!
thetalkingmule is offline   Reply With Quote
Old 09-11-2012, 11:39 AM   #2
Why are you building this out of steel and not just using wooden rafters?
Pressure treated wood in direct contact with even galvinized metal will corrode. Going to have to somehow insolate the two materials.
Your also going to have to cut into the stucco in order to be able to flash where the wall meets the roofing.
http://www.roofkey.com/roof-to-wall-intersections.html
Old 09-11-2012, 12:35 PM   #3
Super Moderator
Have you asked the awning company if they could install the frame for you?
Is that real stucco or Dryvit? What ever it is be sure to sea any penetrations well so water wil not get behind the stucco---
My house's previous owner - DIY horror stories Leah Frances General Discussion 118 03-14-2013 02:27 AM
Basement Ext Wall - Will Rigid Insulation allow my wall to dry inward? COLORADOMTNMAN Insulation 10 01-15-2012 11:09 PM
Mast and weatherhead pulled from house, conflicting information from POCO subcontract SleepnZJ Electrical 1 11-02-2011 10:39 PM
Fixing weekend house staining that went awry jb888s Painting 10 08-17-2009 11:01 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
