Bolting Joists Together - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-25-2010, 01:48 PM   #1
bolting joists together
what are the guidlines for bolting 2x10 lumber together to create a beam?
artmark is offline   Reply With Quote
Old 10-25-2010, 03:31 PM   #2
Registered User
Rewards Points: 4,888
The bolts, spacing, and placement should be on the plans from the Engineer.
If just a built-up header: 14. Continuous header, two pieces 16d at 16" (406 mm) o.c. along each edge.
If you need more strength: http://www.finehomebuilding.com/how-...-up-beams.aspx
What is the application?
Gary
Old 10-25-2010, 04:35 PM   #3
it is a exsisting condition I found there are 6 2x10's bolted with 5/8" bolts top and bottom every 16" inches
Old 10-25-2010, 05:23 PM   #4
Registered User
Sounds as if it may have been inspected or designed by an Engineer. We do have some resident Engineers on here, maybe they will chime in............ Did you try the county records to check for the permit number? It may be on file unless very long ago.
Is something settling or another concern? The bolt spacing, size, and placement would be designed for the loads, span, etc. for each particular case. I know the bolts stay out of the top and bottom 1-1/2" or so of the wood. If just verifying for piece of mind you would hire a local S.E. for an on site visit and consultation.
Gary
Old 10-25-2010, 05:29 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 330
Is there a Problem,..??
It sounds Waay overbuilt...
Bondo is online now   Reply With Quote
Old 10-25-2010, 09:42 PM   #6
I do not beleive there is a problem but thought it was excessive and was concerned about so much wood being displaced it is also side loaded with 6 joists bolted together the same from foundation to a joist hanger with 26 nails?
Old 10-25-2010, 11:26 PM   #7
Registered User
Here one with 72 nails, for a glu-lam: http://www.strongtie.com/products/co...U-HGU-HHGU.asp
Work around here for yours; look on the hanger bottom for the #’s: http://www.strongtie.com/products/al...?source=topnav
Gary
Old 10-26-2010, 09:12 AM   #8
hhus
it is a hhus? I know that to few bolts would be a bad thing are to many bolts a bad thing?
Old 10-26-2010, 04:18 PM   #9
Registered User
Can you give us a close-up picture of the bottom and one of the hanger from 2' away?
Gary
Old 10-26-2010, 08:45 PM   #10
oops
they are hgus 7.25x10 removed more sheetrock my wife is going to kill me the beam is 5 2x10's double bolted at the ends only. the bolts in the feild are alternating top and bottom same with side load, side load holds up 5 joists grouped together running same direction attatched with same hgus and 3 additional joists so my mane concern does that many bolts weaken the wood? and will have failure sometime in future?
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 09:00 AM
Basement cable location on joists BasementVirgin Electrical 12 02-24-2010 11:56 AM
Floor Joists of different sizes HooKooDooKu Drywall & Plaster 7 02-04-2010 06:43 PM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 09:43 PM
help with 2nd floor joists g heil Building & Construction 5 09-12-2008 07:41 PM
