Bolting Down Sill Plate To Stem Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-21-2011, 04:51 PM   #1
liscenced electrician
Rewards Points: 538
bolting down sill plate to stem wall
Im getting ready to pour a foundation and stem wall for a car port. The stem wall is 18' long. The inspector told me to pour the stem wall 6" wide even though its only a 2x4 wall. How often do i have to bolt down the sill plate and what is the minimum size bolt?? Also, can i use a 2x4 sill plate on top of the 6" stem wall?
jimmy21 is offline   Reply With Quote
Old 10-21-2011, 05:02 PM   #2
Framing Contractor
The inspector will obviously have the answers for you. He's the one that will be inspecting it. How come you don't ask him?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 10-21-2011, 05:44 PM   #3
Rewards Points: 538
I'll have to ask him if nobody on here knows the minimum code requirements
Old 10-21-2011, 05:51 PM   #4
Civil Engineer
Rewards Points: 4,854
Jimmy, you haven't even told us where you live, how can you possibly expect anyone to know what the minimum code requirements are for your area? Revealed truth from God?
Old 10-21-2011, 06:04 PM   #5
Rewards Points: 538
oregon. I thought it was a national thing. Guess not
Old 10-21-2011, 06:54 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,242
i dont know what the code is for your region but here its 6 ft o.c. however i put them every 4 ft
woodworkbykirk is online now   Reply With Quote
Old 10-21-2011, 06:57 PM   #7
Rewards Points: 538
found my answers
2304.3.1 Bottom plates Studs shall have full bearings on a 1 1/2 inch thick or larger plate or sill having a width of at least the width of the studs
2308.6 foundation plates or sills foundation plates shall be bolted or anchored to the foundation with at least 7 inches into concrete or masonry and spaced not more than 6 feet apart. There shall be at least 2 bolts per piece with one bolt located less than 12 inches and more than 4 inches from the end of each piece.
Old 10-22-2011, 08:26 PM   #8
nicely done, theres a man with a code book
Old 10-22-2011, 09:41 PM   #9
Rewards Points: 538
Found an online code book on the Oregon building codes website
Old 10-23-2011, 11:52 AM   #10
JOATMON
ddawg16's Avatar
Rewards Points: 1,956
found my answers
That seems to be pretty much standard in most places....
Just one extra thing...if any walls are a shear wall (A, B, C, D), more anchor bolts may be required and if you have a B or stronger shear wall, your mud plate would need to be 3x material.
If you live in a storm area....anchor bolts every 48" would not hurt....
When I did my foundation, I used a grease pencile and marked where each stud would go (16" OC)...then marked where to put the anchor bolts....nothing worse than having to adjust stud position because an anchor bolt is in the way. Make sure you also allow space for the washer...typically 3x3. AMHIK.
Old 10-23-2011, 12:06 PM   #11
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
Hey Jimmy, don't they require plans for projects like this in Oregon?
Andy.
AndyGump is offline   Reply With Quote
Old 10-23-2011, 12:14 PM   #12
Rewards Points: 538
Andy.
Ya, I drew them myself. The inspector is pretty lax on the plans. If something was a violation he would call it but he is good to deal with. If he showe up to inspect he would sure knock you on a violation, though
Old 10-23-2011, 12:43 PM   #13
AndyGump's Avatar
Rewards Points: 684
Well post a picture of them, let's see what you got.
Andy.
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
A/V Wall Plate Configurations: Post Yours! homerb Home Theater 5 10-01-2010 10:49 AM
Half Lap Sill Plate Join Clutchcargo Building & Construction 3 09-05-2008 03:07 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
