Bolt Next To Stud - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-25-2007, 03:16 PM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
Bolt Next to Stud
What can I do when I need to get a lag screw into some structure when the lag screw comes through the wall directly next to a stud?
The picture shows the drill bit for the pilot hole coming through the sheathing next to the stud.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 11-25-2007, 03:34 PM   #2
Eibwen
Assuming you have access to the back side as shown in your picture, just sister up a short peice of lumber to the exisiting to give somthing for your lag to attach to.
Sammy is offline   Reply With Quote
Old 11-25-2007, 03:51 PM   #3
I have gas!
This is a 1/2" lag screw, wouldn't it split them apart?
Old 11-25-2007, 07:10 PM   #4
Rewards Points: 1,538
I am guessing that if you glue the entire mating surface of the sister piece of lumber (at least 12 inches long, hold it on with several wood screws also, and then drill an appropriate pilot hole for the lag screw, you will get an excellent hold and not split off the sister.
Old 11-25-2007, 07:52 PM   #5
I have gas!
I'll give it a shot. Thanks.
Old 11-25-2007, 07:53 PM   #6
Remodeling Contractor
oldfrt's Avatar
Rewards Points: 186
Would a carriage bolt work for you here?
Depending on what your fastening, maybe you could use a horizontal block,stud to stud and bolt through.
oldfrt is offline   Reply With Quote
Old 11-25-2007, 08:35 PM   #7
I have gas!
Possibly, you mean after sistering the studs right?
Old 11-26-2007, 10:00 AM   #8
oldfrt's Avatar
Rewards Points: 186
It would help if you could explain what it is you are attaching with the lags.
If your fastening on a ledger for a deck,is there any reason you can't move the lag over to hit that stud dead on?
Old 11-26-2007, 10:31 AM   #9
I have gas!
This thread actually goes with my bay window bracket thread. I'm attaching functional brackets for my bay window. I could move the bracket over a bit but to keep them centered on the window the other bracket won't center on a stud then.
Old 11-26-2007, 12:19 PM   #10
oldfrt's Avatar
Rewards Points: 186
Damn,
I didn't realize I responded to two threads of yours.I didn't look at the name.
Anyways,sister the stud like Alan J said and use the lag or,recess a carriage bolt into it so it doesn't interfere with your inside finished wall covering.
Finding AC wires with Ryobi stud finder darsunt Tools 4 03-21-2007 07:43 PM
Who makes the best stud sensor? kcrossley2 Building & Construction 6 03-19-2007 11:31 AM
Best reasonable stud finder??? Sellncars Tools 6 10-03-2006 08:29 PM
Attach a bolt to drywall hdayanan Building & Construction 1 03-17-2006 07:01 AM
Stud Finder problem... kalaniwavo Carpentry 4 02-26-2006 07:24 PM
