Board Sheathing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-13-2011, 10:08 PM   #1
Rewards Points: 506
Board sheathing
Is there any advantage to the "old" board sheathing method, versus the more contemporary panel sheathing? Question applies to both roofs and walls.
jlmran is offline   Reply With Quote
Old 01-14-2011, 08:59 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
Sheathing with boards dates back to construction before plywood or composite panels were readily available and were very expensive. I certainly don't see an advantage to using that method today. In fact it would be outrageously expensive to use dimensional lumber today.
Old 01-14-2011, 09:04 AM   #3
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
There are no benefits to using boards. Plywood and OSB in addition to being faster to install, offer shear wall resistance that would need to be built into the framing if sheathing with boards.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
The Following User Says Thank You to Clutchcargo For This Useful Post:
tpolk (01-14-2011)
Old 01-15-2011, 08:50 AM   #4
Rewards Points: 506
How do the panels create shear resistance when the boards do not? Is it a function of the size of the panels? Or how the panels are manufactured?
Old 01-22-2011, 09:58 AM   #5
Diagonal sheathing boards were used for sheer resistance for many years in millions of structures before OSB or plywood became popular.
installing backer board over particle board bob mac Flooring 6 07-16-2013 03:15 PM
exterior insulation foam board sheathing firemem Building & Construction 5 04-29-2010 06:51 PM
luxaire/york 33109167000 furnace board replacement check HVAC 18 07-13-2009 10:03 AM
New roof and Sheathing - Install new fascia before or after? hartkem Roofing/Siding 2 06-01-2009 12:12 PM
wall sheathing, foam board, insulation and house wrap dr.demento Building & Construction 10 10-18-2007 04:42 PM
