Board-formed Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-20-2010, 03:06 PM   #1
board-formed concrete
When I try this with rough sawn the "fuzz from the boards ends up stuck in the finish when i strip the forms, how can I prevent this?
toliver is offline   Reply With Quote
Old 11-20-2010, 04:04 PM   #2
Rewards Points: 1,092
My dad used to oil the boards w/ drain oil; only used them a few times, but it seems to have worked. Can you wrap them w/ visqueen?
Old 11-20-2010, 05:23 PM   #3
Rewards Points: 1,232
Oil the forms with either commercial form release or 5 gal diesel to 1 quart motor oil, but the diesel/oil will stain the concrete.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 11-21-2010, 03:01 AM   #4
Rewards Points: 4,750
finish'd lumber OR wax'd paper,,, there is form release agent you can also buy,,, isn't it illegal to use diesel or oil on forms anymore ? seems like 20syrs by now but maybe i'm wrong.
Old 11-21-2010, 06:46 AM   #5
Concrete & Masonry
Rewards Points: 620
Form release, as noted above, or just power wash after stripping the forms.
jomama45 is offline   Reply With Quote
Remove mastic/adhesive from concrete? FixyChik Flooring 2 03-19-2011 09:18 AM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 09:37 PM
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General DIY Discussions 9 04-11-2010 06:11 AM
Concrete over foam board Mudball Building & Construction 16 01-11-2010 10:03 PM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
