Blueprint - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-28-2010, 02:44 PM   #1
blueprint
I need help creating measurements for a record display case any ideas on how to start or if their is a software program preferably free that will help me get the correct dimensions?
RosenJC is offline   Reply With Quote
Old 09-28-2010, 06:06 PM   #2
Rewards Points: 5,336
Is this sort of a bookcase type structure? One facing deep?
Details are a little vague.
Ron
Old 09-29-2010, 12:42 AM   #3
Blueprint
Ron, Thanks for the reply.
I am trying to build a bookcase style record holder that tapers from thin on top to wider on the bottom. I want to be able to have two sides and have it open to reveal as one ex: like a car door. Also I want the front (and back) of the furniture to hold records front out and a few across and and few down and several deep. I have about 500 records so I plan on having 4 across and 5 or 6 down with about 10 deep set up as layers. Any idea how to star? Thanks.
Joshua
Old 09-29-2010, 07:33 AM   #4
I use a program called, Cutlist when I design cabinets. It's more for planning optimal use of sheet goods, but you might look at it.
The design you propose is somewhat unusual, so you might try doing it the old fashioned way, paper and pencil.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
RosenJC (09-29-2010)
Old 12-04-2010, 09:31 AM   #5
There's also BoardPlanner (http://www.vivbuilder.se, click on boardplanner). Simple to use and not too expensive.
Sapel is offline   Reply With Quote
Reading a blueprint wiz561 Plumbing 10 09-10-2010 04:04 PM
blueprint help please? DangerMouse Building & Construction 8 07-08-2009 11:32 AM
blueprint symbols jimmy21 Electrical 2 06-30-2009 09:08 PM
Reading a blueprint? GYP? Yeti Building & Construction 7 10-23-2007 10:27 PM
