Blue Board As Wall Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-30-2010, 08:12 PM   #1
Blue Board as wall insulation
I plan to insulate my wood frame garage. Any issues with ripping 2" blue foam board (DOW) and friction fitting it between the 2X4 framing? Is it better to hold the edge flush to the inside or push back tight to the exterior sheathing? The plan is to heat as needed, especially when working on projects over the winter months. I do NOT anticipate keeping it at a constant temp. The interior finished wall will be 1/4 luan. The exterior is 1/2 sheathing, tyvek, and cedar clapboard.
Sully
nsully is offline   Reply With Quote
Old 07-30-2010, 08:19 PM   #2
You mean 2" blue rigid insulation ?
It is cut & inserted in wall cavities...it must be tight
Or caulk any rough edges
Insulation is usually faster & easier
Blue board usually refers to drywall
The Following User Says Thank You to Scuba_Dave For This Useful Post:
Gary in WA (07-30-2010)
Old 07-30-2010, 09:45 PM   #3
Registered User
Rewards Points: 526
OP, start reading on page #93: http://books.google.com/books?id=Eq1...page&q&f=false
Be safe, Gary
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 12:35 PM
attic insulation / knee wall oscarMadison Building & Construction 2 01-19-2010 08:37 PM
Blue Board georgetax General DIY Discussions 7 11-11-2005 09:05 PM
