Blown In Insulation Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-22-2011, 03:01 PM   #1
Rewards Points: 206
Blown in insulation question
I have a project that I am doing for a friend where I need to insulate two walls surrounding an entryway that is very cold. The walls are already up so I would need to blow the insulation in from the top of each stud bay. My question is, is there some kind of diy insulation kit for this or does anyone have a better idea, without taking down the walls? Thanks
joeg679 is offline   Reply With Quote
Old 01-22-2011, 03:30 PM   #2
BIGRED
Rewards Points: 252
Remove the drywall and insulate it right the first time. You don't know if there are firestops in the walls and removing the drywall will let you put up plastic vapor barrier sheeting so you can seal around the receptical and switch boxes and make sure any windows and doors are weather chinked properly as well.
Grampa Bud is offline   Reply With Quote
Old 01-22-2011, 06:03 PM   #3
Registered User
Rewards Points: 5,236
How old is the house/entryway?
Is the cavity assessable from the outside- vinyl or Hardie siding?
If you rent a blower and cellulose, do you have other areas to fix?
You could dense pack it compressing the existing insulation, without a vapor barrier and probe for fire-stops; http://www.karg.com/pdf/Insulaton_de...and_Biddle.pdf
Gary
Old 01-22-2011, 06:16 PM   #4
Rewards Points: 206
It's actually a condo that was built about 8 years ago. The outside is brick, so it's not accessible. No, there are no other areas to fix, so I guess renting a blower would not be worth it. Do you know how much the blowers rent for? Thanks a lot for the info, I appreciate it.
Old 01-22-2011, 07:55 PM   #5
Registered User
Most box stores rent the blower free after you buy the product.... Call locally, price changes with location.. Location also warrants vapor barrier or not.
Gary
Old 01-22-2011, 08:08 PM   #6
Rewards Points: 206
Gary
Great, thanks. I'll call HD and Lowes and check the local codes.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 01:42 PM
blow in insulation question Cool user name Remodeling 4 12-31-2010 12:24 AM
Sheetrock And Insulation Question kn1564 Remodeling 4 04-23-2010 12:24 PM
old blown insulation djknob Building & Construction 3 12-29-2008 12:20 PM
