Blown In Insulation Over Bats - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-11-2010, 11:22 AM   #1
Blown in insulation over bats
Is it okay to add blown in insulation over existing bat insulation? We have R30 bats in place. Thank you for any info on this subject.
Marc7747 is offline   Reply With Quote
Old 10-11-2010, 02:01 PM   #2
Registered User
Rewards Points: 4,914
If the existing insulation is fiberglass batts, I would definitely add cellulose over it to stop the wind-washing and convective loops heat loss you have now. 7" (R-20) of blown cellulose at 1.5# per cubic ft. would add 1# over each square foot compressing the batts, losing some R-value. Take two full12oz. pop cans and lay them 12 apart on the insulation, measure the area between them, the decrease in height of the batt compared to unloaded. This would be the same as adding 5 of cellulose. Next, take the compression distance and compare it to the chart for compression, underlined at the bottom: http://saveenergy.owenscorning.com/2...nd_your_2.html
Basically, 2 compression = R-5 reduction, 4 compression = R-9 reduction.
The added insulation acts as a blanket covering the more air permeable batts similar to blown-in loose fill low-density (0.5) fiberglass. Test results were 30-50% loss of R-value at 60-70* inside when temperature dropped outside: http://www.homeenergy.org/archive/he...92/920510.html
The cellulose layer added on top the fiberglass greatly increased the resistance with a further test: http://docs.google.com/viewer?a=v&q=...SWhJRhM2V4M5EQ
http://infrared-energy.com/files/Spe...onProblems.pdf
Add enough cellulose to make up for the compression loss of the weaker fiberglass.
Gary
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 01:42 PM
Has anyone used Green Fiber blown in insulation? pomelo Building & Construction 7 02-10-2010 08:17 AM
Flat Roof and Blown Insulation... inlikeflint Building & Construction 4 01-26-2010 01:42 PM
Blown insulation Xtreme_99 General DIY Discussions 1 01-05-2009 06:56 AM
