Blown In Insulation Covering - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-18-2010, 11:51 PM   #1
Blown in insulation covering
I have blown in insulation in my unfinished walkout basement. They put some kind of thin white cheesecloth like material over it to keep it place. I am now finishing my basement and need more of it to hold in insulation on interior walls between finished portion and storage areas. I took a piece to lowes and hd and they looked at me like I was nuckin futs. Any clue as to what this stuff is and where I can get it?
mathias400 is offline   Reply With Quote
Old 03-19-2010, 08:30 AM   #2
Remodeling Contractor
the problem you have is this is not a correct installation. For walls you need to use a wet mix dense packed cellulose insulation. Remove what you have and add it t the attic. For basements use only foam insulation. Either sprayed or rigid foam.
Old 03-19-2010, 09:52 AM   #3
Maybe I should have elaborated, the blown in is only on the portions of the walk out that are stick framing, not concrete, there is no issue with this is there? I have put up foam insulation on the concrete and am framing against that before I fill it with insulation. The interior walls I am building which are not againist concrete are going to have insulation blown in and is where I need the paper covering
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 01:42 PM
Has anyone used Green Fiber blown in insulation? pomelo Building & Construction 7 02-10-2010 08:17 AM
Flat Roof and Blown Insulation... inlikeflint Building & Construction 4 01-26-2010 01:42 PM
Blown insulation Xtreme_99 General DIY Discussions 1 01-05-2009 06:56 AM
old blown insulation djknob Building & Construction 3 12-29-2008 12:20 PM
