Old 04-27-2010, 08:23 AM   #1
blown in insulation calculator?
Anyone know of any good blown in insulation calculators? I need to figure out how much blown in insulation I need to insulate a garage... only 3 and a half walls are to be insulated... (one of them is just plain fiber glass faced batts right now)...
the dimensions of the garage are 20x27x11 with one wall (15ft long) already insulated...
also what is the best type of blowin in to use? I've seen everything from shreaded newspaper treated with fire retarder to ground up cotton like substances
BlueBSH is offline   Reply With Quote
Old 04-27-2010, 12:01 PM   #2
It was a dark and stormy
Yoyizit's Avatar
http://en.wikipedia.org/wiki/R-value_(insulation)
You know the R-value per inch. Figure the $/inch for the R-value you need to choose a particular type.
Tags
blown insulation
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 01:42 PM
Has anyone used Green Fiber blown in insulation? pomelo Building & Construction 7 02-10-2010 08:17 AM
Flat Roof and Blown Insulation... inlikeflint Building & Construction 4 01-26-2010 01:42 PM
Blown insulation Xtreme_99 General Discussion 1 01-05-2009 06:56 AM
Vapor Barrier & Blown in Insulation barbe4 Building & Construction 1 12-03-2007 09:05 PM
