Blown In Insulation Added To Fiberglass Batts - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-10-2011, 08:40 PM   #1
Blown in insulation added to fiberglass batts
Does adding blown in insulation to fiberglass batts really help?
bsbrooks1 is offline   Reply With Quote
Old 02-10-2011, 10:38 PM   #2
Registered User
Rewards Points: 5,212
Yes, if the batts are low density and the blown-in is not also;http://www.diychatroom.com/f98/how-b...ulation-90438/
Gary
Old 02-10-2011, 11:43 PM   #3
Rewards Points: 336
It brought my heat bill down quite a bit. But I also sealed the attic before adding the blown in insulation. You might want to consider doing that before adding anything. It's very important. Lift every batt and look underneath.
Gary, excellent thread you started about fiberglass insulation. All of the links are very helpful!
gma2rjc is online now   Reply With Quote
The Following User Says Thank You to gma2rjc For This Useful Post:
Gary in WA (02-11-2011)
Blown Insulation Over Porch pankaek Building & Construction 8 01-31-2011 05:26 PM
cellulose over blown in fiberglass? deerhunter Building & Construction 1 10-29-2010 11:16 PM
blown in insulation calculator? BlueBSH Building & Construction 1 04-27-2010 12:01 PM
removing blown in insulation brownerd HVAC 2 08-09-2006 12:53 PM
Blown Insulation indiancollector Roofing/Siding 1 01-26-2006 11:38 PM
