Blowing In Sidewall Insulation With Thin Batts In There - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-13-2010, 07:03 PM   #1
Rewards Points: 562
Blowing in sidewall insulation with thin batts in there
on my present project(old siding removed,previous to typar and vinyl siding) I was going to blow the sidewalls with cellulose or fiberglass thru the 3/4 sheathing on outside walls.
come to find 2 " batts of mineral wool in there. Can I still blow 'some' in there or is that causing more harm than good? would you 'aim' for the outside of the present batt or inside?
4just1don is offline   Reply With Quote
Old 09-15-2010, 05:31 AM   #2
Rewards Points: 562
opinions please????
anyone have a guess?
Old 09-15-2010, 05:19 PM   #3
Registered User
Rewards Points: 5,514
Very hard to get any kind of quality with them in there. If they rip and drop while filling, even worse. Compressing the existing will negate it and adding another won't give you the R-value as if it wasn't there. If the old is faced, it should be to the warm in winter side if in a cold climate. Using dense-pack cellulose may work better, if done by a professional.....
Gary
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Hybrid wall insulation consisting of 2" rigid foam + 2x4 fiberglass batts? TitaniumVT Building & Construction 15 09-14-2010 02:50 AM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
Blowing In Cellulose Insulation - Need Advice gma2rjc General DIY Discussions 26 04-13-2009 08:13 PM
Attic Insulation, Blown-in or Batts Tony Papa Building & Construction 13 05-21-2007 06:19 AM
