Old 09-07-2010, 01:56 PM   #1
Blowing cellulose through top plate
There is one wall along the front of my house that I am trying to find the best spot to gain access through to which I can blow cellulose insulation into. I have clapboard siding and the front of the house has a nice coat of paint that I really hate to disturb by pulling siding. The inside is wallpaper, so I'm not willing to mess that up by blowing from the inside.
I do however have direct access to the top plate through the attic directly above. I need to basically run a 1-1/4" hose through the wall to insulate. How bad of an idea would it be to drill a 1-1/2" hole through the top plate in this area. Along most of this run the top plate has nothing on top of it, so I could easily add a new 2x4 directly on top once finished. Is this a bad idea??
Master Brian is offline   Reply With Quote
HELP PLEASE replacing rotted sole, top and bottom plate dolson Remodeling 4 04-16-2010 07:54 PM
Replacing Section of Sole Plate RM575 Carpentry 3 03-28-2010 10:31 AM
Getting Steel Plate Flush with Concrete Floor MrBill_DIY Flooring 7 11-29-2009 09:54 AM
Insulation - Cellulose vs. Icynene meth Building & Construction 24 04-29-2009 10:12 AM
Blowing In Cellulose Insulation - Need Advice gma2rjc General Discussion 26 04-13-2009 09:13 PM
