Old 05-24-2009, 09:16 PM   #1
Blow-In Insulation on Sloped Ceiling?
I'm at the insulation phase with my house and there are two rooms with vaulted ceilings (but flat top), around a 4/12 slope (30 degrees). Do you have to use bat insulation on those or will the blow-in insulation stay there. I'm sure you'd have to build it up at the base a little bit but I've never used blow-in.
The largest room is about 16'x16', so the side of the ceiling that's slanted is about 7 feet with about a 4' wide flat section at the top. Please help the dummy. Thanks!
TheGrinch is offline   Reply With Quote
Old 05-24-2009, 09:22 PM   #2
Xtreme DIY'r
Are the ceilings vented - soffit & ridge?
Old 05-24-2009, 09:46 PM   #3
Soffit (vinyl) vented every third. Ridge top vents span all of the ridges of the house.
When I say "vaulted". It's not like a real vaulted ceiling. The real roof is several feet above the ceiling.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Blow in insulation Iowabucks General Discussion 1 10-09-2007 09:20 AM
Vaulted Ceiling Insulation Problem casey_wa Roofing 13 05-08-2006 10:55 AM
