Blow In Insulation. Identify Asbestos. 30s-50s - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-04-2010, 08:08 PM   #1
Rewards Points: 242
Blow in insulation. Identify asbestos. 30s-50s
I am working on a house that is said to be "built" in the mid 50s. I know for a fact that the house was moved here so I think it might have been built previous and the county recorded it as 50s when it was placed. In any case, I am working in the attic and the insulation definitely is NOT fiberglass. Act very much like shreaded cardboard if you ask me. particles become airborn very easy. It is light brown just like cardboard. It does not really cling together but rather just acts more like cellulose. Just clumpy.
Is there a good way to tell if it contains asbestos and how much exposure do you need to have major health problems?
viper is offline   Reply With Quote
Old 09-04-2010, 09:14 PM   #2
Rewards Points: 502
I'm hardly an expert, but here is what I know;
All the asbestos I've seen has been gray. It has also all been in sheet form, wrapped tightly around pipes, or in old brake pads.
Asbestos is like cigarette smoke. even a little does some damage, but nobody knows how much it would take for any particular person to develope cancer. speaking of smoking, you are at a much greater risk if you are around it and you smoke, think 5% + 5% = 35%
The particles are incredibly small, but even a regular mask would probably help some. a wet filter would probably help more than a dry one.
forresth is offline   Reply With Quote
Old 09-04-2010, 10:11 PM   #3
fabrk8r
fabrk8r's Avatar
Google " vermiculite " and see if it looks like what you are dealing with.
If so, then you should have it tested before stirring any more particulates up. There are numerous companies that do asbestos testing and they will tell you how to take a sample.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 09-04-2010, 10:12 PM   #4
Rewards Points: 562
asbestoes
it IS found in many products from that era, drywall,insulation,linoleum, plaster,stucco as a short example. Point is you wont know what it is till you send a sample to a asbestos lab and have it tested. no shortcuts to that.
4just1don is offline   Reply With Quote
Botched asbestos removal in home... runfrombears General DIY Discussions 28 07-31-2012 09:21 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
blow in insulation ( paper ) deck hand Green Home Improvement 4 01-10-2009 09:57 PM
Can anyone identify this insulation? White Elk General DIY Discussions 8 10-23-2008 08:35 PM
Blow in insulation Iowabucks General DIY Discussions 1 10-09-2007 08:20 AM
