Blockwall Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-09-2010, 10:25 PM   #1
nj7
Question
Blockwall Basement
I am thinking of finishing my blockwall basement.Are there any codes of construction or other reasons why the people who sold the house to my girlfriend 10 years ago made sure she understood that the basement could never be finished?
nj7 is offline   Reply With Quote
Old 10-09-2010, 10:55 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
maybe. There are codes in some areas that would prevent certain basements from being used for living space. The first one I can think of is headroom both ceiling height in the basement and headroom on the stairway. There are even more rules that would limit the possibility if one intends on using the space for sleeping rooms.
Old 10-10-2010, 11:22 AM   #3
nj7
Blockwall Foundation
There is no issue with headroom & I don't intend on putting in bedrooms. Can you or anyone else please give me anymore information on the finishing of a blockwall basement?
Old 10-10-2010, 12:27 PM   #4
concretemasonry's Avatar
Rewards Points: 2,608
You might run into entry/egress problems. The window used must be an approved window with a clear opening meeting the minimum dimensions. There is also a requirement for the open sill height (42 or 44 inches depending on the local requirements). You also must have an accessible area outside that could require a pit/recess wide enough to permit use by a firefighter with tanks and gear.
Dick
concretemasonry is offline   Reply With Quote
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 07:40 AM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 07:46 PM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 08:49 AM
Insulating basement ceiling - your recommendations? jtmann HVAC 8 11-24-2009 04:44 PM
