#1 |
Blocks or poured concrete for round tower?
I am planning a 20 ft tower, 10 ft diameter, as a very distinctive tool shed on a 1.25 acre plot. It will be faced with brick veneer, and look a bit like a castle tower. Cheaper to use cinder blocks or poured concrete for the structure? Or just a wood frame? The foundation will be rebar/concrete.
#2 |
Agent 000
I'm not a contractor, but here's a couple of observations.
Just my random uninformed thoughts. |
#3 |
Why not just use multi-wythe brick construction? In lieu of that, CMU would be faster, cheaper, and easier. If CMU, you will probably want to use 6x8x8 units.
#4 |
General Contractor
Poured concrete, using a slip form system, would be the most expensive option to consider....and it is done on grain silos....the forms are set to diameter, and then as the pour progresses, the forms are "jacked" up with the set....
Ladwig Construction
Hennessey, Oklahoma 405 853 1563 |
#5 |
Agent 000
Blocks or poured concrete for round tower? |
#6 |
General Contractor
Most would never guess, but when you see pictures from the heartland of America, and all those huge grain elevators, multi tower units.....remember they are monolithic pours that in some cases, continued non stop for a few months....modern techniques make it easier, but in the old days, the forms were jacked by a crew of men walking the scaffold around the form and turning a jack screw at each station, then going to the next station...that way the form didn't get a lead higher on one side.....now they use lasers and hydraulics to do it....but it is still done. I have seen one built in recent times,....all the rest around here are from the early part of the century....my Grandfather and his brothers helped crew a few of these.
Ladwig Construction
#7 |
Thanks for the insight, and story. There is a huge difference between a silo and a grain elevator. I used to live in Illinois, and Oklahoma, so I am familiar with these. I am now in Connecticut. Not much farming here!
#8 |
Most elevators I see are slip-formed, while most silos are metal. I have seen slip formed cisterns on homes in Fredricksburg, Llano, and Lampasas, probably of the 1900-1930 era.
| Display Modes | |
| Sleeve options for plumbing through concrete? | Bruce L | Plumbing | 6 | 06-14-2008 10:38 AM |
| Math check on amount of concrete for poured foundation? | Badfish740 | Building & Construction | 10 | 05-05-2007 07:49 AM |
| How do you measure poured concrete PSI? | head_dunce | Building & Construction | 18 | 02-25-2007 09:58 PM |
| stone veneer formula | tom1st | Landscaping & Lawn Care | 1 | 07-08-2006 05:48 PM |
| Need to expand existing concrete pad for A/C unit | miketegra | Building & Construction | 2 | 07-03-2005 11:27 PM |
