-Blocks- - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-03-2006, 11:23 AM   #1
Construction Man
Chuckman's Avatar
-Blocks-
can someone tell me how many blocks i would need for a 35x30 building and its gonna be 15ft high. imput greatly appreciated!
Chuckman is offline   Reply With Quote
Old 06-03-2006, 01:14 PM   #2
PRO
Glasshousebltr's Avatar
2200 8x16s
Bob
glasshousebuilder.com
Glasshousebltr is offline   Reply With Quote
Old 06-03-2006, 09:28 PM   #3
Construction Man
Chuckman's Avatar
how do u calculate this?
Old 06-03-2006, 10:02 PM   #4
General Contractor
joasis's Avatar
math works everytime...you can go the long way...wall length X height = square feet, then the .88 sq/ft/per block.....- windows, doors, FO's, and allow for corners.
joasis is offline   Reply With Quote
Old 06-04-2006, 10:11 AM   #5
Construction Man
Chuckman's Avatar
im having a 9x10 garage door and a regular walk-through door? how would i calculate that?
Old 06-04-2006, 10:24 AM   #6
PRO
Knock off 90 for the garage door and 20 for the entry.
49 sticks of vertical rebar 32" OC in filled stretchers, filled corners.
I'd start with 100 bags of 50lb morter and figure my use for a second delivery.
Because your headed up 15 feet, it might not be a bad idea to use block wire.
Bob
Old 06-04-2006, 10:33 AM   #7
Construction Man
Chuckman's Avatar
so that would be 2090 thanx and by the way i got my floor poured for my garage yesterday i gotta give it time to set and it was pretty warm last nite lol it should be ready to set blocks on by tomorrow or tuesday
Old 06-04-2006, 04:31 PM   #8
You'll also need to add more blocks if the 15 feet height you mention is the finished height above grade.
Remember that you need 6 more courses or more below grade depending on frost depth or whether there will be a basement below the structure.
manhattan42 is offline   Reply With Quote
Old 06-04-2006, 05:22 PM   #9
Construction Man
Chuckman's Avatar
nah this just 1 story no basement and the floor is 6inches thick so its good and strong to hold it...
Old 06-04-2006, 08:56 PM   #10
A 6" slab is inadequate as a footer in most locations for a block structure of this sort, especially if you live in a high seismic zone and are subject to freezing.
What state? What County?
Old 06-05-2006, 04:45 PM   #11
Construction Man
Chuckman's Avatar
haha kentucky, usa; and 6inches is adequate enough to hold my truck so well its to late to change anything because i already started blocking it i got about 5 feet of block on it now so
Old 06-06-2006, 06:24 PM   #12
Construction Man
Chuckman's Avatar
ive got it all blocked now ive worked day and night now i just gotta wait 4 weeks for my garage door and entry door, lowes doesnt carry 9x10 heres so they had to order it.
Old 06-06-2006, 11:00 PM   #13
renovations
So how many blocks did you use? Show us some pics.
Bonus is offline   Reply With Quote
Old 06-07-2006, 07:07 AM   #14
Too Bad
It is a code violation to not install proper footings in Ketucky.
Kentucky uses the International Residential Code 2003 statewide.
Without proper footings installed below frost level, this building will remain unstable.
Sorry.
AAC or standard CMU blocks oar Building & Construction 3 06-10-2008 06:43 AM
Glass or acrylic blocks ? amakarevic Building & Construction 2 03-31-2008 06:14 PM
Blocks or poured concrete for round tower? silverfrost1 Building & Construction 7 07-13-2007 09:27 PM
What am I doing wrong on these blocks?! joeyboy Building & Construction 26 06-01-2007 01:15 AM
title over cinder blocks micheleb General DIY Discussions 2 03-22-2005 04:56 PM
