#1 |
Blocking for Non Load-Bearing Wall
Need to put in blocking for Non Load-Baring Walls and need to know the size of nails to use, how to install them (toe nail or nail through joist and into blocking) and how many nails to use?
#2 |
Residential Designer
If you can (and if I understand the question) nail through the STUDS into the ends of the blocking.
Most areas require fire blocking every 8 feet. Andy.
Residential Drafter/Designer To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 | |
Blocking for Non Load-Bearing WallQuote:
Andy.
#4 |
What I am trying to do is install blocking between floor joist in order to attach the top plate to the joist. This is for a non load-bearing interior wall. The joist run parallel with the wall so I need blocking to attach the top plate too and need to know what kind of nails to use, and how to install the blocking (do I nail through the joist on one side into the blocking or do drive the nail in at an angle going from the blocking into the joist, and how many nails do i use to keep it secure?)
Thanks for any help |
#5 |
I usually specify blocking for this kind of thing every 24" O.C. Use 16d. common or green sinkers, nail from joist into end of blocking if possible.
Andy.
| The Following User Says Thank You to AndyGump For This Useful Post: | mae-ling (03-28-2012) |
| Tags |
blocking, nail, non load bearing ![]() |
| Display Modes | |
| Do you think this wall is load bearing? | rchickering | Remodeling | 17 | 11-21-2011 06:35 PM |
| Is this wall load bearing - pictures attached | jen5219 | Building & Construction | 16 | 08-01-2010 01:17 PM |
| Load Bearing Wall Issue? | iggy913 | Building & Construction | 1 | 07-28-2010 07:45 PM |
| Wall - LOAD BEARING: How to Move? | user49172 | Building & Construction | 1 | 03-11-2009 05:48 PM |
| Load Bearing Wall | rpatterson | Building & Construction | 2 | 10-29-2005 08:43 AM |
