Old 01-23-2009, 10:11 AM   #1
Blocking necessary
Is blocking necessary if a header is nailed directly to the top plates? It also has double king studs. It wouldn't be much trouble to add blocking.
bluefitness is offline   Reply With Quote
Old 01-23-2009, 11:22 AM   #2
Not so new
12penny's Avatar
Blocking necessary
Hey blue, if you're talking about trimmers ... yes you do. Doesnt matter if its a window or a door you must have something under header to support it.
12penny is offline   Reply With Quote
Old 01-23-2009, 12:29 PM   #3
Moderator
Termite's Avatar
Blocking necessary
Not too sure I understand the question. As 12penny correctly stated, trimmer studs are always required under the header in addition to kingstuds up the ends of the header. The only blocking I can think of would be cripple studs between the header and the top plate if you were to install the header lower than you are.
Old 01-23-2009, 01:31 PM   #4
I have gas!
Clutchcargo's Avatar
Blocking necessary
bluefitness, are you referring to cripples?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 01-23-2009, 01:54 PM   #5
Blocking necessary
Sorry guys. I might be using the wrong terminology again. I'm referring to a piece of wood that is placed between the last king stud and the next adjacent stud. It is usually just a piece of 2X8, 10, or 12 in (I guess what ever is on hand). It is to prevent the header assembly from shifting to the side.
Old 01-23-2009, 02:42 PM   #6
Moderator
Termite's Avatar
Blocking necessary
Let's check terms here. Kingstuds are full height studs in the wall that but up against the end of the header, and the header is nailed to the kingstuds to keep the header from "rolling".
Trimmers are studs that the header actually sits on. There are usually 1 or 2 trimmers on each end of a header, depending on the header's length. Trimmers and kingstuds touch, and should be nailed together.
I cannot imagine where blocks would be installed.
Old 01-23-2009, 06:53 PM   #7
Blocking necessary
Here is a picture of what I'm referring to:
Instead of a 2x4 laying flat, a 2x8 or larger is put vertical. It is placed in the space adjacent to the king stud and next stud.
Old 01-23-2009, 09:17 PM   #8
Moderator
Termite's Avatar
Blocking necessary
Ahhh, now I got it. The blocking isn't critical to the framed opening. In some cases the sheathing of the exterior of the house needs the edges blocked so they can be nailed off. This depends on sheathing orientation, house design, and local requirements and accepted practices.
The blocking is of NO VALUE unless you can nail the exterior sheathing to it from the outside. If you can't, don't lose sleep over it.
Old 01-25-2009, 07:00 PM   #9
Professional Wood Shafter
ryanh's Avatar
Blocking necessary
I have never seen blocking just by the window's king stud before. Some areas require blocking on studed walls for fire blocking but if its just by the king stud unless its to keep the window rough opening straight and plumb maybe. Never had to do it that way before
ryanh is offline   Reply With Quote
Fishing a wire around blocking? rjniles Electrical 10 12-16-2008 11:14 PM
installing wood blocking sonnycrockett General Discussion 8 06-15-2008 06:39 PM
Blocking Help evolve Building & Construction 11 11-16-2007 03:53 PM
Sub Floor Blocking? dgranum Building & Construction 6 09-07-2007 06:30 AM
Basement blocking ksypal Building & Construction 2 03-26-2007 08:53 PM
