Blocking Deck Joists - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-01-2010, 01:45 PM   #1
Rewards Points: 154
Blocking deck joists
I am using 2x10s for deck joists. In one section they are 8 1/2 feet long from ledger to rim board. Should I put in blocking? Would I notice the difference when I walk on the finished deck?
ovahimba is offline   Reply With Quote
Old 03-01-2010, 08:16 PM   #2
firehawkmph's Avatar
Rewards Points: 1,920
Ova,
8 1/2' span on a 2 x 10 isn't that much to worry about. On the other hand, if you feel like doing the blocking, it won't hurt any and will normally stiffen up the floor.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 03-01-2010, 09:27 PM   #3
jlhaslip's Avatar
Rewards Points: 2,862
consider a line of blocking on a diagonal to stiffen the deck. works particularly well on decks a couple of feet off the ground.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 03-02-2010, 08:01 AM   #4
Rewards Points: 154
Thanks for the feedback. I have a couple of really warped boards I couldn't use for anything else. Might as well chop them up and hammer them in.
pressure-treated wood for deck joists? beiley Building & Construction 16 02-26-2013 07:27 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
Connecting a deck ledger to blocking? ovahimba Building & Construction 7 06-11-2008 05:20 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 11:05 AM
Concrete deck -- rotting floor joists jwill Building & Construction 6 09-05-2007 08:01 AM
