Blocking Between Floor Joists - Important? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-18-2013, 12:55 PM   #16
cortell's Avatar
Rewards Points: 504
Originally Posted by ddawg16 View Post
Hopefully Daniel H will chime in...
What would we do without Daniel and the Garys to keep us amateurs in check?!
cortell is offline   Reply With Quote
Old 10-18-2013, 05:26 PM   #17
43 years in construction
Arkitexas's Avatar
Dear advocate of the Devil,
Alignment: This is not a code requirement but rather a side benefit, I apologize if I made it sound otherwise.
Rolling-Bracing: Bottom chord bracing (strapping) is another method to brace the joists and is permitted by the R502.7.1 of the IRC. In my personal opinion (and not required in the IRC) bottom cord bracing should have structural terminations (triangulation, panelizing, X bracing, bridging, etc.) at each end of the run to be as effective as continuous blocking. There come those pesky squeaks again. In commercial steel construction such terminations are standard.
Squeak Sources: I don't contest that blocking was the source of the writer's squeaks and it appears that he has found a better floor assembly that is quiet. That said, it has been my experience floor squeaks have nearly always been attributable to poor deck attachment to the joists and/or marginal joist sizing. In any case, thicker floor decking and adhesive is a good upgrade which, in addition to improved load distribution, also adds mass bettering the sound deadening qualities.
Dismissive: I disagreed with the first paraphrase of the article "bridging does little more than cause squeaks" and the second quote that "......seasonal changes in humidity cause the joists to shrink and swell enough to render any type of bridging worthless". Wood framing does in fact shrink and swell but that doesn't make the bridging worthless. I think I would have been more agreeable had he described bridging as unacceptably annoying.
Other Alternatives: a) Use galvanized steel bridging which does not vary dimensionally with humidity levels. b) Switch from wood framing to steel.
Rick
Arkitexas is offline   Reply With Quote
The Following User Says Thank You to Arkitexas For This Useful Post:
cortell (10-18-2013)
Fire Blocking Basement 325_man Building & Construction 20 01-27-2013 09:01 PM
Open cornice rafter bay blocking. diyroofer Building & Construction 7 09-05-2011 01:55 AM
Is blocking required for ceilings? ChrisJJ Drywall & Plaster 3 08-22-2010 11:47 AM
HVAC and Joist Blocking Question bassprokd HVAC 3 02-25-2010 06:42 AM
Fishing a wire around blocking? rjniles Electrical 10 12-16-2008 11:14 PM
