Old 02-15-2007, 01:44 AM   #1
block walls
okay folks need some suggestion ! have a block wall im building
the first wall is 8"x16"x150ft behind that is a 16" planter then behind the planter is another wall thats 8" x 4ft x 150 i have a seperation in the wall for the walkway ------ ------ at the walkway entrances i need to put a collum at both sides right now im planning on a basic square 24x24x 4ft6" but wanted a newer look. Im laying block tonight will leave collums for last thanks.all your suggestions would help !! thanks
orenawilliam is offline   Reply With Quote
Old 02-15-2007, 10:55 AM   #2
block walls
You could use bullnose block to give the columns rounded edges for a nominal increase in cost.
Tscarborough is offline   Reply With Quote
Old 02-15-2007, 01:00 PM   #3
concretemasonry's Avatar
block walls
Depending on your budget and where you are, you could use some split architectural block and really have an accent at the entrance/walkway. If you have a good local block producer, you may be able to buy a few split corners (8x8x16) as an over-run for a large job.
In any case, make sure you have adequate vertical reinforcement in the wall and especially at the ends.
concretemasonry is offline   Reply With Quote
FINISHING BASEMENT WALLS - Cinder Block Walls tmacwith Building & Construction 4 12-06-2012 09:26 AM
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Concrete block - bond pattern tvoltz Building & Construction 1 06-11-2007 07:36 PM
Best way to insulating a heated detached cement block garage Joe Nulph Building & Construction 1 03-06-2006 11:30 AM
