Old 06-20-2010, 02:25 AM   #1
Block Wall
How high canI build a residential cinder block wall
Billrv is offline   Reply With Quote
Old 06-20-2010, 06:16 AM   #2
Block Wall
in theory, there's no difference between theory & practice,,, in practice, there is,,, how high did you have in mind ? 4 or 5 floors shouldn't be a problem,,, the problem will be cinder blocks below grade because, if you do the nec dampproofing your bldg code requires, eventually the foundation will rot,,, suggest you, at minimum, use concrete block.
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Old 06-20-2010, 07:39 AM   #3
Block Wall
As suggested, technically, there is no limit. Local codes usually determine what is allowed.
Hole in concrete block wall jjrbus Building & Construction 4 06-05-2010 02:32 PM
What to do with windows when firring out from a block wall. willemdejong Carpentry 1 06-04-2010 12:25 PM
Patch cement block wall? k.kuenn Building & Construction 4 05-31-2009 08:40 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
