Block Paving Disaster? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-07-2009, 09:20 AM   #1
Unhappy
I've recently found out the the previous owner of my house has laid the block-paving driveway incorrectly. The driveway has covered the air bricks to the house and I now have a damp problem. I've been told the only solution is to remove all the bricks from the drive, then to dig about a foot down and then relay the block drive. Its quite a big drive and the problem runs from the front, round the side and at the back of the house. Is there any other way of fixing this problem???
Linda Coleby is offline   Reply With Quote
Old 06-07-2009, 04:22 PM   #2
If I understand correctly, the brick driveway was laid against the lowest level of brick on the house, causing water infiltration into the weep holes in the brick.
I had a similar problem with my house, whereas a brick patio was laid against the brick veneer and caused spalling of the lowest level of brick.
An option may be to pull the brick from around the home and replace it with concrete poured at an appropriate level. Of course you will have to ensure the grade is proper to flow water away from the house... Think of a concrete walk, or some sort of garden.
If this will not work in your situation then, yes, the driveway will have to be re-laid.
Reilley is offline   Reply With Quote
Old 06-07-2009, 06:11 PM   #3
I would remove enough paving stone to allow access to the brick wall. Dig down to the brick footing and clean it off using water and a wire brush.
After the brick surface is clean, apply a parge coat over the brick and then after this is setup, apply a coat of foundation sealer to the parge.
Backfill the excavation and replace the paving stones.
new vent holes should be drilled into the mortar above the paving stone level.
Old 06-07-2009, 06:13 PM   #4
Civil Engineer
Rewards Points: 4,566
Reilley, I don't think that is what the OP means. An air brick is a ventilated brick that allows air to move through the brick. It is generally used in houses where the wood floor is exposed directly to damp air in the crawl space under the house. The idea of the air brick is to allow air to move through the crawlspace, reducing the "dead moist air" problem under the house by allowing ventilation.
I believe the OP means that the air brick on at least one side of the crawl space was covered up with earth as part of the driveway installation, thereby preventing air from flowing through the crawl space. In order to fix the problem, it is certainly necessary to remove the soil that is blocking the brick. Without some photos or a good diagram, it is impossible for me to further understand the problem.
Old 06-07-2009, 06:18 PM   #5
Ahh I see now. I hadn't heard of an air brick before. I agree, pictures would certainly help.
Old 06-07-2009, 08:46 PM   #6
Hmmm! Air brick! Would this be a brick with holes running horizontally? If so, I have never encountered such an animal. I thought that we we talking about weep holes that are placed on the bottom course of brick!
If its a ventilated brick, I would plaster the vents closed, parge and waterproof the wall.
Old 06-08-2009, 11:43 AM   #7
Thanks guys, it looks like I have to bite the bullet on this one and have the drive taken up and relaid.
Old 06-08-2009, 03:54 PM   #8
Rewards Points: 1,910
How did you come to that conclusion Linda? That wasn't what anyone on here suggested. Can you post pics and explain exactly what the problem is?
Old 06-08-2009, 05:37 PM   #9
Yes! Why this solution?
Driveway excavation, $10,000??? Parge and waterproof, $500!
Old 06-08-2009, 07:10 PM   #10
I agree, this can be extremely costly for something that may not really be the best solution. Have you spoken with a contractor? One may be able to do a repair job that will only be a fraction of the cost of what you are suggesting.
morrill is offline   Reply With Quote
Brick Ledge when using cinder block DaveMo Building & Construction 5 07-13-2011 10:46 AM
Cracks In Block Wall Foundation vf100 Building & Construction 7 08-20-2008 10:48 PM
Cutting cinder block for a large door opening joeyb Building & Construction 2 02-10-2008 01:00 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
